thanks, I wanted to upgrade the drivers because they are 40 years old and my AMP is very high poweredCan you fix the drivers? What’s in poor shape? Also, those gray bomb capacitors may be an additional source of poor sound.
I ask because it may be difficult to match new drivers to the enclosure. JVC likely designed them around that sphere.
That picture of the good one, The other one the cones are torn because they are old and my amp is Very high power. I was hoping someone replaced the drivers with aftermarket ones..ThanksThey don't appear to me to be in poor condition. Have you actually removed the drivers from the cabinet to see how the cones look?
Hi, What kind of caps do you recomend? Thanksthanks, I wanted to upgrade the drivers because they are 40 years old and my AMP is very high powered
You'll have to get the values off the original caps. Parts Express is generally the go-to recommendation for reasonably priced capacitors.Hi, What kind of caps do you recomend? Thanks
Pull the woofers with the torn cones and post pics. Is it the cone itself, or the surrounds that are torn, BIG difference. Surrounds can be easily replaced. Torn cones can be repaired by cutting pieces of coffee filter paper glued to the back side of the cones, use some Eileens Tacky glue and repair the BACK SIDE of the cones. Get the cone tear area as close to original position as possible, then proceed with the repair. The coffee paper pieces should extend about 1/4 inch past the damaged area.That picture of the good one, The other one the cones are torn because they are old and my amp is Very high power. I was hoping someone replaced the drivers with aftermarket ones..Thanks
