Janochytron
Hi,
I am fixing JVC-JAS22. One of the STKs is blown. They are STK0040.
I can find both 0040 and 0040II. The II version much cheaper. Can use 0040II instead of 0040?
As per the datasheet pins 4-7 on 0040 are not used (they are not connected to anything in the amp either) while the version II uses them. But if I connect the 0040 without these four pins connected, would it perform the same as 0040?
datasheet:
http://pdf.datasheetcatalog.com/datasheets2/14/149839_1.pdf
Thanks
Petr
datasheet:
Thanks
Petr
