Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Just got a used JVC QL-F4 (great looking table). Everything works except the 33 speed (45 is spot on). Anyone have any experience with fixing quartz-locked tables? I do have some DeoxIT D5 here. What should I check for?
Where should I spray the Deox? I've only ever used it a couple times and only on external connectors. This will be the first time I've ever opened up a TT.
Also I noticed some black grease on the spindle when I removed the platter (not much but enough to wipe off with a paper towel). I'm just a bit frustrated with the seller who packaged the TT with the platter still on and the cartridge and counterbalance still attached. Cartridge is bad somehow since it doesn't give a signal to the left channel (I double checked a good cartridge from my other table). He has stopped responding to my emails regarding the 'issues' I've been having with his product. In fact he took offense and pretty much stated that it wasn't his problem (to sum it up) in a very childish way.
As to the deoxit, do you have PITCH controls ? I don;t think the QL4 does so all speed is controled by the quartz lock logic.
Hope not for your sake but check this..if you can get the service manual there may be some adjustment POTS inside the table the have little flat blade screwdriver slots so you can tweak it in and the table does the rest...but if they are way off or oxidized, they can throw it off...
I'll take a peak for you but its one of the reasons I keep stearing away from these even though I like them. If they get speed issues, you need to be an electrical tech to fix..if at all
It does have a pitch control to dexoit...but you still may have to find the adjustment inside...I can;t get into VE right now (for some reason after a few views it keeps me out for a little while..have no idea why)
acrorob: Thanks I will try and take a look when I get home from work today.
mackat: The seller wrote me back berating me once again and telling me it's my fault? Not sure how that is. I paid for the item and as a Buyer that's my main role isn't it?
The funny thing is I just bought a Realistic Lab-400 on ebay and THAT seller really exceeded every aspect of that sale down to the beautiful attention to packing details. Man I wish there were more like him around.
Quick question, what is the difference between a DeoxIT D5 and the others? I think I read somewhere that the D5 doesn't evaporate as quickly? I had sprayed some a few months ago on a receiver and got a drop or two behind the main glass. A couple of spots still remain. Do I need to manually wipe those out with a rag or will they eventually disappear?
Th next step is to open an official eBay case, follow the instructions, and they'll decide in who's favor they want to rule. I've heard it works out a lot.
I did just that. The speed issue I have sounds relatively easy to fix but its the poor professionalism and attitude that makes me want to do a full refund. I guess claims gives the other guy a week before I get to escalate. I'm certain they'll make me wait that long out of spite. First claim I ever had to do unfortunately. The table looked so slick too. I'm going to ship it back to him the same way it came to me.
Do you know how these claims work? Do items need to be shipped back before the transfer of money or are refunds held in escrow?
I have the same problem with the same turntable: speed is fine at 45rpm, but slow at 33rpm. Am I looking at a trip to the tech, or is there a relatively straightforward fix to attempt first?
The real question is whether yours is not switching to 33 properly or if something in the adjustments for lock is out... if it's the latter you'll need an oscilloscope to adjust the lock.
Post up your location, you may have an AK member with a scope local who'd be willing to help.
