Troy Kilian
Hey folks so I have this old JVC stereo receiver that has been sitting around for years because the main fuse kept blowing. So I finally took the time to investigate and surprisingly I found that the output transistors on the left channel were blown. Now I really have no idea what I'm doing and am a complete newbie at this so I need the collective help from all of you geniuses on here. If you guys don't mind, it would be so appreciated! After I found the left output transistors blown I pulled them out replaced the fuse and powered the receiver up just fine. Hooked up an audio signal and got output audio through the right channel on a speaker. So I figured the short had to do with thermal overload and thought I could just replace the output transistors and be on my way. I was lazy and just found NTE's as replacements instead of the original SK's (plz don't call me dumb I didn't know what I was doing at the time) and those blew out too. So I'm not sure where else the problem could be. Was it just the shitty replacement transistors I used or is the problem somewhere else? I've checked many transistors verifying that they are okay and I also checked the emitter resistors and those are okay too. I have a service manual you guys can check and show you what I have gone through so far. http://freeservicemanuals.info/en/servicemanuals/download/JVC/rx-503bk.pdf
