JVC VC-9 60 HZ Pulley Needed
Texun1
Well-Known Member
I own a JVC VC-9 that came with a 50 HZ pulley installed. Needless to say it runs very fast. I have searched high an low for a 60 HZ pulley to no avail. Does anyone here own this model. If so could you mic the pulley and give me the od on the 33rpm section of the pulley. I will then take it to the machine shop and have it turned.
Thanks,
Bill
Have you looked under the platter and or inside the base? :scratch2:
On some models the 60 hz pulley come as an extra/accessory.
It is often held by a screw under or inside the base of the turn table.
Thanks for the suggestion but no luck. Still searching... someone out there has to have one. :yes:
