ViperZ
Well-Known Member
Hi all,
I got JVC VL-5 belt-drive turntable, installed the new belt (old one was completely disintegrated), balanced the arm, set the weight, etc etc. Bottom line it works fine manually.
I cannot figure out functionality of the cueing lever. It does not work properly on this table. I can see the mechanism under the platter engaging (when everything is taken apart), but the arm does not lift when I push the lever, nor does the arm lift when the record ends - it kind of lifts a bit, goes back 2 inches and drops back onto the record.
I do not see anything broken. I removed the bottom cover - I can see the metal part that's supposed to push the little hydraulic lifter. I don't understand why it's not engaging - the gears under the platter seem to be engaging when Cue lever is pushed.
Service manual is on VE database is essentially a copy of the user manual, so not much of help...
Thank you.
Thank you.
