JVC VR-5501 Lamp replacement?
jleon92f
Addicted Member
Hi All,
I just picked up a JVC VR-5501 receiver and (2) of the dial lamps are out.
The Bulbs are screw in type rated @ 8V 0.3 A. Does anyone know where these are available? Radio Shack does not list an 8 Volt bulb.
Thanks,
John.:music:
hi John,
Try www.digikey.com and look in the optoelectronics section. I just tried to find a replacement for you there, but I'm not getting an exact match. Can you take a picture of the lamp(s) so we can see what we're working with? Also keep in mind that you can use a similar replacement lamp with a slightly higher voltage and amperage rating if need be.
hi John,
Hi,
Thanks for reply, Pictures in on the way. 8v 0.3 A ? 0.3A is How many Amps?
Thanks,
John.:music:
Hi Gang,
I went digging through the stuff I had here and guess what I found some bulbs from a bunch of stuff I bought off the www.
And they work too! This is good enough for now.
Later,
Thanks everyone.
John.:music:
The threaded 8v/300ma capsule shaped lamps are still available from various sources. :yes:
