JVC Zero Series
Forster
Member
Hello,
I have just come into the possession of a pair of JVC Zero 5 speakers. In powering them up I was rather surprised at the excellent quality of the sound, but can find nothing about these speakers in the way of information, date of manufacture etc.
They are a three way, ribbon tweeter, double ported design, my spine told me to inform you that they are very heavy!
Anybody out there come across these before?
many thanks - Forster
I've heard of a few of the "Zero" series,including M. Jarve's Zero 9s.
Everything I've read about them has been quite positive.
The zero series was JVC's statement speaker system. I have two sets of zero9's, as mentioned above, and I will be buried with them. I've been trying to find some others, but they seem to be rather rare. The zero5 was from the original series (there were several "series" bearing the zero tag), and were one step down from the 9's. The 5's came in a few different flavors http://page.freett.com/knisi/zero-5.htm (page is in Japanese, but you can still glean some useful info even if you're not a manga otaku (^.o) ).
The signature component, of course, is the planar ribbon tweeter, one of the first from a Japanese manufacturer. The midrange driver is a sort of early cone/dome hybrid. The large aluminum cap is not just for show- the driver is essentially a dome with a paper lip. The bass driver in the 5 is the same as the mid-bass driver in the 9’s (save that it is 8-ohms instead of 16), and is a sort of paper/fiber composite. Other highlights include a phase-corrected crossover, fixed resistor attenuators for the mid and tweeter (with 5% non-inductive resistors) and an internal baffling system meant to eliminate standing waves without using creative cabinet work.
I have heard a multitude of speakers in my short life and I can confidently say they are among the finest (if not the finest) general purpose loudspeaker I have heard. Definitely keepers, or if not, send them to me!
(picture courtesy of Axel)
The JVC Zeros I've heard, Mike 9's, were one of those audio moments where my jaw just dropped at how good the speakers sounded. I just never thought JVC could produce a speaker of that quality.
You have some winners, give them a good home.
Some information and specs in German from my small Archive.
JVC Lautsprechersysteme
Sie mögen sich vielleicht fragen, ob die Technologie für Lautsprecher in den letzten Jahren mit den Entwicklungen' für Verstärker, Tuner und andere Hi-Fi Ausrüstung Schritt gehalten hat. Die Antwort lautet: Nein. Aber jetzt hat JVC's Bändchenlautsprecher die etwas vernachlässigte Lautsprecher-auslegung um einen gewaltigen Schritt vorwärts gebracht. Endlich gibt es, einen Lautsprecher, der den breiten Frequenzbereich und die tatsächliche Dynamik der Originalmusik vollständig und klar wiedergibt.
Dyna-Flat Bändchenlautsprecher
Der Dyna-Flat Bändchenlautsprecher bietet; weitaus mehr Dynamik, und Sie erzielen optimale Resultate von den neuesten Audiogeräten und ihrem Zubehör. Seine Membran besteht aus einer sehr dünnen Folie Polyamidharz, in welche die Schwingspule integriert ist. Dies ergibt eine Einheit, deren bewegliche Masse lediglich 0,048 Gramm beträgt. Die Membran wird gespannt, um eine konstante Oberflächenspannung zu erreichen, und dann zwischen zwei Magnetsätze eingelegt. Wenn Strom in die Spule des Hochtonlaut-sprechers eintritt, bewegt sich die Folie (Membran) gleichzeitig. Auf diese Weise versetzen sogar die winzigsten Signale die Membran in Bewegung. Ein weiterer Vorteil besteht darin, daß die umschließende Luft von der gesamten Membranoberfläche verdrängt wird und nicht nur von einem oder mehreren Segmenten. Dies führt zu dramatischen Verbesserungen im Einschwingverhalten. In JVC's ZeroLautsprechersystemen sind ausgeglichene verbesserte Mittelbereichund Tiefton-Treiberstufen-in Baßreflexgehäuse integriert.
3-WEG BASSREFLEX LAUTSPRECHERBOXEN
Dyna-Flat Bändchenlautsprecher für einen flachen Frequenzgang bis über die Hörschwelle von 50 kHz.
Kalotten-Trichterlautsprecher für einen breiten Mittelbereich ohne Spaltvibrationen für eine ideale Klangverteilung. Alpha-Trichtertieftöner mit hoher Leistungsfähigkeit für dynamischen Baß, reduzierte Verzerrung und verbesserte Linearität
Konische abnehmbare Ziergitter, Pegelregler, vordere Resonanzwand mit zwei Öffnungen, schwarzes Furniergehäuse und manches mehr.
Zero 5
Typ 3-Weg, 3 Lautsprecher Baßreflex
Tieftöner 30 cm Trichter
Mitteltöner 10 cm Kalotte/Trichter
Hochtöner 5,2 x 0,8 cm Bändchen
Frequenzgang 30-50.000 Hz
Belastbarkeit (Spitze/Nenn) 200/100*Watt
Wirkungsgrad (1m in Achse) 92 dB/1 W in 1m Abstand
Impedanz 6 Ohm
Maße (H x B x T) 655 x 365 x 340 mm
Gewicht 21,5 kg
*DIN-Norm
Michael-Otto
Zero 5
Impedanz 6 Ohm
Gewicht 21,5 kg
*DIN-Norm
I'm sorry...what?
Hallo Michael!
I have a cousin that lives on Carl-Kistner Straße in Freiburg. It really is a small world.
Hello,
Many thanks for your very useful help, especially the Japanese site with an internal photograph. It looks to be a very well designed speaker and certainly sounds far better than one would hope for.
The woofer reminds me of one that I saw in a JBL unit some years ago.
Best regards - Forster
Zero 5
Impedanz 6 Ohm
Gewicht 21,5 kg
*DIN-Norm
Michael-Otto
Googles version of the above.
JVC of loudspeaker systems They may perhaps ask themselves whether the technology held for loudspeakers in the last years with the Entwicklungen' for amplifiers, Tuner and other rear-Fi equipment step. The answer reads: No. But JVC's brought neglected loudspeaker interpretation now to small band loudspeaker the something around an enormous step forward. Finally is there, a loudspeaker, which shows the broad frequency range and the actual dynamics of the original music completely and clearly. Dyna Flat small band loudspeaker
The Dyna Flat small band loudspeaker offers; optimal results of the newest audio devices and their accessories obtain more dynamics, and you by far. Its diaphragm consists of a very thin foil PP resin, into which the moving coil is integrated. This results in a unit, whose mobile mass amounts to only 0.048 gram. The diaphragm will strained, in order to achieve a constant surface tension, and then between two magnet-corrode inserted. If river occurs the coil of the Hochtonlaut-sprechers, at the same time the foil (diaphragm) moves. In this way even the tiniest signals shift the diaphragm in motion. A further advantage consists of the fact that enclosing air is displaced by the entire diaphragm surface and not only of one or more segments. This leads to dramatic improvements in the transient behavior. In JVC's ZeroLautsprechersystemen are integrated balanced improved Mittelbereichund Tiefton driver in bass reflex housings.
3-WAY BASS REFLEX LOUDSPEAKER BOXES Dyna Flat small band loudspeaker for a flat frequency response to over the auditory threshold of 50 kHz. Kalotten horn loudspeaker for a broad central range without gap vibrations for an ideal sound distribution. Alpha Trichtertieftöner with high efficiency for dynamic bass, reduced distortion and improved linearity Conical removable grilles, level controllers, front resonance wall with two openings, black veneer housing and some more.
Zero 5
Type 3-Way, 3 loudspeaker bass reflex
Tieftöner 30 cm funnels
Mitteltöner 10 cm Kalotte/funnel
Hochtöner 5.2 x 0.8 cm small bands
Frequency response 30-50,000 cycles per second
Power Handling (point/call) 200/100*Watt
Efficiency (1m on axis) 92 dB/1 W in 1m distance
Impedance 6 ohms
Mass (H x B x T) 655 x 365 x 340 mm
Weight 21.5 kg *DIN-Norm
