KA-6160 Shorted. SOS!
NickDeO
Hello AK,
I’m working on a KA-6160 receiver that needed a few new caps in the power supply. In attempting to adjust the bias after properly installing the caps, it appears that at least one of the output transistors has shorted. Now, the DBT is fully lit and nothing powers on. The only fuse I can find has not blown. Before I start tearing everything apart and testing individual components, what would you guys suggest I do? Thanks!
I believe the short happened on the transistor on the right side. Maybe the collector made contact with either the base or collector?
On a side note, I really prefer working on newer designs with better utilization of PCBs. This receiver is a cluster of discrete components soldered together into a bit of a tangled mess. It’s like playing Operation, but with greater consequences! :confused:
Remove and test the output transistors in the channel you shorted out.:thumbsup:
