Gobstopper
Hello Everyone,
I recently started working on a KA-7100 that I found on the sidewalk several years ago. I used a DBT and it started up okay. Initially sounded pretty scratchy and dropping out, but Deoxit on switches and pots + manipulation seemed to clean it up nicely. The one thing I found is that sound only plays if tone defeat is engaged. If I switch it to "off", then there is a horrible loud noise in both channels(can't hear music anymore). Looking at the schematic it would seem that something is wrong upstream of Qi5 and Qi6 (where it enters the tone controls). I just started testing voltages(haven't tested every corresponding point with a labeled voltage on service manual), and so far the only thing that seems a bit off is the voltage at the (base of Qi10)/(Collector of Qi8) (reads -11V instead of -10V). The collector and base of Qi10 read a bit more in spec(-11.25V instead of -11@collector and 12.6V instead of 12V@emitter) Should I keep testing voltages in that area, or is there a more likely source causing the problem?
I'm not a full fledged pro, but I have refurbished several units in the past (mostly pioneers and one marantz)
