KA-92B Amp not outputting left channel
Cricketgg7
Hey y'all, I've been all over the web and made an account here hoping for some assistance.
I'm trying to set up my parent's old Kenwood system and running into a block with the KA-92B stereo amp. I'm not getting any audio or signal into the left channel at all, on either bus.
I've 2 speakers and tested them both with different wires and tested most of the rca inputs with different devices, and I can confidently narrow it down to the amp itself having the issue. The headphone output also only gets the right signal, btw.
I've noticed on the decibel meter that I get a light on the right channel but not the left, regardless if any input/output is plugged in.
This system hasn't been used in quite a while, 20+ years at least, so I'm unsure if wear has caused any issues. But I'm wondering if this is a common enough issue that a new cap or transistor can fix.
The only workaround I've found is plugging both speakers to the right channel on the 2 busses, but that's obviously just a doubled right signal, not a mono setup by any means.
Any advice would be much appreciated.
Welcome to AudioKarma!
tape monitor work for both channels?
i skimmed the schematic and you could try cleaning the switches.
20+ years is a long time sitting unused. maybe a cap failed.
you will need to download the schematic (see hifiengine) and check the PS voltages.
if the ps voltages look good, Does the relay click after about 5 seconds?
if not, measure the anode and cathode of D17. I think this will turn on the protection relay.
if relay doesn't click, post voltages on IC5. be very careful not to short any pins. pins 2 look like the sensing voltage. if pin 2 is not 0, your channel is probably bad and you will need to either send it to a tech or start learning the joys of electronics.
it may not be worth sending out. not a lot of value in these 100 w/c integrated amps.
