okeeteekid
Well-Known Member
I bought this pair of K9's in 1989, I'm the original owner, when I was in the store I couldn't decide between the black and the golden oak, I thought the oak was too light in color for my living room decor so I got the black.
Well when I got them home the black didn't match my decor either so I decided to sand them down but leave the black color in the fluted grooves.
I then stained them in a medium walnut color and cleared them with 4 coats of polyurethane (I know what was I thinking sanding down a brand new pair of speakers).
Well all I can say is that I was glad I did because they turned out really nice, way better than I thought they would turn out.
That was 28 years ago and the finish still looks the same as the day I did them.
They weren't that hard to do either, I didn't remove any of the drivers, you can also tape plastic tupperware bowls over the drivers for extra protection, I just used masking tape and newspaper to cover the front and backs of the speakers, I used an orbital sander to sand them, I started with coarse sand paper and worked my way up to finer sandpaper until the wood was smooth, you don't really have to worry to much when your sanding because the wood is solid oak not veneer so you will never wear through the wood, you just have to try and not run the sander through the masking tape areas on the speakers and just be careful not to bump into any of the drivers if you didn't cover them with the bowls.
It probably would have been a lot harder if you wanted to sand the black color inside of the fluted curves so that's why I decided not to do it Lol.
All in all it wasn't that hard to do if anyone is thinking of doing theirs, A dark rosewood or cherry pair of k9's would look awesome.
I'd sure like to hear something like that I bet they sound magical.
. so that's that LOL.
