Alec Heggen
Hello, I know its cheesy to make your first post in any forum one asking for help but I've got a 1974-76 Kenwood KD-5033 that needs a little help. I've already done quite a bit of cleaning underneath and oiling the internals as well. However, despite everything else working perfectly (cuing in, auto-return) the actual lifting mechanism and drop dampening on the KD-5033 is hopeless. I have to slowly lower the tonearm manually and I cannot set the auto-return at all or it will just scrape the stylus across the entire surface of the record on it's way back to the tone-arm's rest. And a majority of the time it just hits the support of the rest and stops rather than making it in because again, it doesn't lift the tone-arm before engaging auto-return. Because of this I've been using it manually but I'd really like to restore it to it's Factory Fully-Automatic function. If anyone has any tips or tricks, maybe they've even worked on this turntable before and they know exactly why I'd be so stoked! But I know this is a bit of an unusual and maybe even obscure TT in comparison to some of the other Kenwoods like the KD-500, 850 and so on. ANYTHING IS APPRECIATED!
