Mystery
constantly upgrading...
As many of you know, I got JBL L36 few months back that had woofers replaced with car subwoofers.
Today, I picked up a pair of L26.
The cabinet is dry, missing a small chunk in one speaker's top back and discolored so it needs some sanding, oil and stain.
All drivers and tweeters work fine.
Interestingly, these are same size of L36 but felt lighter.
Looks like PO used external fuse holder screwed near the terminals. :scratch2:
So I'm wondering whether I should re-foam and keep L26 as it is or part it out for the woofers to use in L36. L36 will need quite a bit work to make them look good as I need to remove the black paint, plastic grills, order grill pegs etc... while the L26 need just some TLC on dry and discolored cabinet.
Thanks for suggestions.
Are L36 worth the trouble over L26?
