ThisWoofer sag. Very common. If rotating doesn't work, gently peel away the rubber surround, align the cone and re-glue. Done it a dozen times.
Got it. Thanks guys. Remove rubber surround and re-glue using rubber based glue, with shims in place, right? Is it a must to remove the dust cap? Does this afford for easier re-centring? Can it be done with dust cap in place? Thanks a lot, JonThis
Update on an old thread. I took the plunge and simply removed the rubber surround as Baco99 suggested. It came apart easily and I re-centred the cone with the driver facing upwards. Re-glued and checked centring by playing music whilst the glue dried. Simple as that- job done! Driver sounds as good as new with absolutely no cone rub! Thanks for the tip!
So, digging up this old thread reminded me of the problem, and I checked my repair. With closer listening and a good in-out physical check it seems that all is not well with the driver. Although there is no apparent voice coil rub, the driver just doesn't seem to have the same travel (and therefore bass response) of the other, healthy one. Is this a repairable issue? Or does it mean the bextrene is just past it's best, stiff, as it were?I bought a pair of 103.2s in April 2016. I drove each with a bridged NAD 2155 Amp, 150 WPC peak. After a couple of months one speaker sounded like it had been blown. I finally removed the woofer last week and now think that it might just be spider sag. When I move the speaker in and out on each of 2 sides, I hear the noise but not when the third side is expanded/compressed. Does this sound like speaker rub? Thanks.
Hi Raynald, thanks for your help. The surround seems fine in itself. Only the cone doesn't have much travel and the whole unit doesn't seem to move in-out well (even though there is no rub to speak of). I also realised that a visiting toddler had nicely pushed the dust cap in too, which wouldn't have been helping! So I bit the bullet and purchased a used driver from the auction site yesterday for $30. It's not in mint cosmetic condition but sold from a store, apparently in fine working order. I'll see how that works! Cheers, Jon PS- Whats the best thing to clean these drivers with to remove dust and maybe even to return faded colour to proper black? Stupid to use "back to black" that works on car tyres?The bextrene is in the cone, what would limit travel is the rubber surround. Poking it with your finger does the surround from the bad driver seem different from the good one? If not it could be a voice coli or spider issue, just off the top of my head.
