Kefowner554
Hi, I own a pair of KEF 103/3 speakers. One of the woofers works fine, and the other has a bad voice coil rub. The bad woofer is quiet and distorted. I read some things in the forums about fixing a voice coil rub, but the issue is that in these b200 sp1217 woofers, the voice coil gap is tiny and hard to get at because of how they are built. I tried working on it, but I can't get the rub to go away. I have laid out 3 possible options from here:
1) Try to find an OEM replacement (None Available right now). There is one available on eBay: https://www.ebay.com/itm/256339349631, but it does not have the original rubber surrounds and instead, they replaced them with different shaped foam ones. It also looked like they did a sloppy job on the dust covers.
2) Find an audio repair shop (repairs might not be possible and it would probably cost more than it is worth)
3) Try to find 2 good replacement woofers that fit in my KEF 103/3's.
I think the best option is 3, but I have no idea how to find a viable replacement if one even exists. Any comments or ideas would be appreciated.
