Although looking for sonic comparison, here is the technical data.
Updated info is here:
KEF Concerto (1969-1977) system SP-1006 version (2 earlier types differ)
3 way
13 x 9" B139-A6171 woofer flat oval
5 " B110-SP1003 mid bextrene cone
3/4" T27-SP1032 tweeter melinex dome
bass reflex
isolated mid internal enclosure
db efficiency not sure
28 x 17 x 12"
50 lbs
8 ohm
30 w, maybe more
cross at 400 & 3500 Hz
crossover DN12-SP1004
30-30,000 Hz range
including the earlier two Concerto versions - the 3 versions complete arrangements are:
System A6614- woofer is B139-A6171 & mid is B110-A6362 & tweet is T27-A6340 & crossover is A6606 earliest version
System SP1005- woofer is B139-A6171 & mid is B110-A6362 & tweet is T27-A6340 & crossover is SP1002 mid-era version
System SP1006- woofer is B139-A6171 & mid is B110-SP1003 & tweet is T27-SP1032 & crossover is SP1004 latest version (most interesting to me !)
KefKit3 (1969)
3way
13 x 9" B139-SP6171 early & SP1044 later, oval woofer
5" B110-SP1003 mid
bass reflex
96 db sensitivity
28 x 14 x 10"
28 lbs ea
8 ohm
15 to 50 w
25 to 40,000 Hz range
IMF Compact Monitor III (1980-1986) and also IIIa version (1981-1987)
3 way
8" IMF-branded KEF B200, or Dalesford or IMF-branded Elac woofer plastic cone
4" Elac 4/200 mid plastic cone
1" Audax 12 X 8 (or X 9) D 25 SP or IMF-branded TW1500 = a rework of Peerless DT 10 HFC tweeter soft dome
bass & mid each in seperate tapered cabinet internal sections
84 db efficiency
24 x 12 x 12"
29 lbs ea
8 ohm
20 to 150 w
cross at 375 & 3000 Hz
29-to inaudible (minimum 20,000 or better) Hz range
not sure of model or type #'s of crossover=likely IMF-branded in-house built
IMF Super Compact (1973 to 1980 version I) & (1979 to 1985 MK II)
3 way
8" IMF branded KEF B200 (large magnet version)=version I then IMF-branded Dalesford 8/22 SP1014=version Mark II woofer bextrene cone
4" Elac 4EM/101 or some EMI=version I then Elac 4/200=version Mark II mid bextrene cone
1" IMF-branded reworked Peerless DT 10 HFC=version I then Audax HD 12 X 8 D 25 SP=version Mark II tweeter soft dome
bass reflex
midrange short transmission line
100 db efficiency, but about 84 db at 1 w
18 x 11 x 12"
20 lbs ea
4 to 8 ohm
20 to 50 w, maybe more
30-20,000 Hz range
not sure of model or type 's# of crossover=likely IMF-branded in-house built
Spec-wise it's a shootout, so curious for sonic impressions comparisons
Best help may be our UK friends here which may have heard any of the FOUR speaker models
The exact model & type #'s of crossovers not listed (for IMF speakers) is unknown so far
Any of 3 Concerto versions and 2 Super Compact versions info welcome
Speakers are in no particular ranking order - each owner has preference(s) for 1 or more models !
Any thoughts ? Eager to learn of the sonic comparison & impressions of the FOUR speaker models
