We've talked about the Model 11's before I think. I'm biased, I like them.
I have a Model 11G, and a Model 11 Kenwood. Both are real nice examples.
My undestanding is that the 11 models were primarly sold through US miliitary PX's, during the 70's.
I got the 11 from the original owner, and it had never been opened, and it only needed one AM indicator light. I cleaned it up, cleaned the controls, and it works great. Wood case is excellent.
The 11 was the first of the 11 models. Later came Model 11's - II, III, G. There may be other Model 11's, not sure.
The timer works fine on both of mine. You can set timer for up to two hours, and the unit will shut off at time set.
The 11 as mentioned is 60 wpc. Has excellent tuner. Has lots of features, dolby for recording. Dimmer switch for dial. (tuning dial looks alot like the KR9600) Has 4 meters. Just a nice overall receiver. It is larger than most other receivers. (wider)
Mine has wood case. Actually, most all Model 11's I've seen have wood cases.
The 11G is a big daddy behemoth, large, heavy, and powerful. Probably a like a KR-9600, or Marantz 2325. 120 watts per channel. Has superior tuner section.
And it's really neat when when lit up. Has cool dial, lighting. One of the neatest I've seen.
The 11G is in the same class of a 9090DB Sansui. Maybe was made for that purpose??
My 11G works just as good. (I have a 9090DB to compare)
The 11G is a keeper. (and a sleeper)
If you have a chance to get one, they're an excellent buy. Probably can get one for half the cost of a 2325 Marantz, and cheaper than a 9600, or 9090DB too.
