What happened to "no attitude"?
Are you jealous if I did?
Actually, I spent quite a bit more for my KR-9050 than I did my MAC-4100.
The MAC 4100 uses two rows of 5 pushbuttons for speaker and tape monitor selection. The pushbuttons are soldered to a PCB and that PCB is secured to the front chassis by two screws, one on each end switch, leaving the remaining 3 pushbuttons mechanically unsupported. When the buttons are used, especially the buttons in the middle, the PCB board flexes and this flexing leads to solder joint failure, which is a typical failure on the 4100 selector board.
Incidentally, Sansui and Pioneer use similar push switches and always use at least one screw per switch, which prevents the PCB from flexing.
The McIntosh uses LEDs, including on the needle for the tuner. The Kenwood uses bulbs.
The McIntosh uses an sealed volume pot, I'm assuming an alps. The Kenwood does not.
