Cody AOC
Hi so recently I bought a Kenwood Basic M2 amplifier off someone for $5 yes it does work but it does not have the 2 prong power entry connector. Somebody took it off and it's not anywhere but I can't seem to find a replacement for it this is one of the units that has a voltage selector on the back right under where the power cord should be so when I brought it home I had to solder a cord on it to test it works like new little dusty but can always be cleaned so if anyone can provide me a link to somewhere that i can buy this power entry connector but as a 2 prong version since i tried using a regular 3 prong power entry connector and it did not fit it was too big to fit.
Would this work? Midway down this page, on the right side.
Go to the DRM Audio page and email Daniel to get his PDF catalog.
http://www.drmaudio.com
You can get a modern 3 pin plug and lead with a template to set it up for $15.
Well worth the $$$
Good luck
Hi, do you know what is going on with his site? I'm asking because the you've obviously been in touch with the guy and your message is relatively recent.
I looked into buying something from him a few years ago (see below) and he was apparently moving and was unable to take requests. I just did a search again and I saw his site was still up. On the 'what's new' section he refers to an August 2017 catalog so I see he hasn't completely disappeared, but on the 'contact' page it says the site is 'temporarily closed'.
The part I'm looking to buy is the relay adapter, on the http://www.drmaudio.com/mod-kits page. My Nikko Alpha 220s also use the obsolete Omron G2Z-222P relay and while neither of them have gone bad, I'd like to have the kit on hand if and when they do.
