Kenwood Eleven III timer
truck
AK Subscriber
Picked up an Eleven III from an AKer and the timer just spun around. I picked up a brass rod at Lowes. Put 4 holes in it and some threads. The only screws I had that fit the threads were computer case screws. Looks funny, but I can put a full size #2 phillips on it and torque it down. Still have to be careful as the brass is soft.
Timer now works perfectly!
Brass rod = solid. Brass tubing = hollow. I assume you used tubing. ;)
It's a common failure on these units, but I've not personally seen a busted one yet.
broken piece
Actually I used a Red Brass Pipe Nipple 1/8" MIP x 4":naughty:
Here's the broken piece with the screws removed.
Lots of vintage gear use these type of nylon connectors for control shafts, and they are too easily broken...I'll have to remember your little trick here. Nice work. :yes:
I think I would have picked up some very short headless set screws at ACE Hardware (either slotted or hex), but that's a great repair tip!
I still have it open as I'm waiting for some lamps to arrive, might have to stop at Ace and grab some. It's what I had at the time...
That wasn't meant as criticism, and I've done a lot of similar things to test stuff. Just a suggestion. :thmbsp:
