Beavs
Have a Model Eleven III that needed a good cleaning and re-lamp and seemed to be working great on the bench. After getting it all put together letting it play for a few hours, loud distortion would start to develop intermittently regardless of source. I'm making the assumption that transistors or IC's in the control amp section may be the cause and want to have parts on hand before pulling this out of the sleeve again (though open to other opinions, bad solders joints seemed to be a probable cause as well).
Anyway, I have subs on hand for Qi3 and Qi4 on the control amp board. The other two transistors Qi1, Qi2, on that board were stock 2SC1222(U) or 2SC1345(E) which appears to be a known noisy transistor. Looks like standard AK recommendation replacement for these would be KSC1845, but stocks are out on these and I don't currently have any on hand. On a tranny cross reference site I saw 2SC1815's listed as a sub for the stock ones. I have 2SC1815's on hand measuring hFE of 430 and Vf of 670mA, stock link here:
https://www.mouser.com/ProductDetail/512-KSC1815YTA
Would these be suitable replacements? Schematic screenshot below:
Next question about the IC's which are original TA7129P and all that I could find on AK or the rest of the internet was an NTE1462 but generally doesn't seem to recommended as a replacement based on quality. Are there other options for replacing these IC's if necessary?
