jcsul
Member
Around six months ago, my KA-405 started exhibiting some weird behavior. While turning the volume knob, the left channel would sometimes randomly jump up to almost full volume before dropping back down to the expected level. I assumed this was probably just a dirty pot issue. Since the top of the KA-405 case and the volume potentiometer have slots that face the top of the case, I assumed that something slightly conductive must have fallen through the slots on the top of the case and into the volume potentiometer. I put the amp in a closet and planned to give the controls a good cleaning in a few weeks. Well, it ended up being about six months, but I gave all the controls the Deoxit cleaner and lube treatment. I just plugged it in this morning to find out that the left channel is now always on. There's no noticeable static or noise when I'm not feeding a single into the amp, but when I do input a signal, I'm always getting a strong signal through the left channel. I'll bullet point some things below.
- Channel and speaker selectors have to be in the correct position. If I run a signal into the Aux input and set the amp to the phono channel, I don't get any. Same with any other combination of mismatched inputs and channels. So it doesn't seem like a channel or speaker selection switch issue.
- Any signal coming out of the left channel is somewhere around 50%-75% max volume. The volume control has no audible effect (or perceivable on the VU meters) until I crank the volume up around 75% of the way or more. When I crank the volume knob up most of the way, it does make the left channel louder, and that is reflected on the VU meters as well.
- In general, all the controls still work as expected for both channels, other than the weirdness with the volume control. Fiddling around with all the other controls doesn't cause the problem to cut in and out, which leads me to believe this isn't an issue with dirty controls. Additionally, I cleaned all the controls a couple of years ago and everything worked without issue for a solid year or so after that.
I'm considering pulling the volume potentiometer and hooking it up to my multimeter to see if the resistance does anything whacky while rotating the potentiometer's shaft. Other than that though, I'm out of ideas as to what could be the issue. Anyone have any ideas on what could be the issue here? I've repaired a handful of 70s and 80s amps before, but I've never run into an issue like this. Any help would be appreciated.
