Taavip
Hello from Estonia!
Hope you are all well.
Got my hands on this really sweet '77 year Kenwood amp. Unfortunately left channel is dead.
I really like this amp, so I would like to repair and restore it.
Hopefully you can give some little guidance needed to bring this amp back to life.
Before I receive an amp I always do the following:
Left channel bias could not be adjusted really, the adjuster was able to influence from 0-5mV.
Power amp schematics:
I took out all final outputs and they measure ok, also tested q19, q21 and they measured ok. Also the resistors near power amps were ok. Does this make sense considering the dc offset of 2.5v?
Then I started to measure voltages according to schematics from right channel starting from the beginning and here are the results:
R7 14V: 14v
q1+q3 6v: -1.7v
q5 b -41.8v: -45v
q7 e 43.4v: 47v
q7 k 1.2v: 46
q7 b 42.8v: -1.2
q13 e -1.2v: -3.5
q11 e: 1.2v: -1.2
q5 b -41.8v: -45v
Please note the supply voltages are a little higher due to this amp was meant for 220v, but in reality it's 230-240v here.
So I'm seeing a problem with q1 and/or q3 and maybe q7, but not sure since one issue can affect another.
Based on these results what do you think could be the problem or problems?
I'm having a hard time ruling out either q1 or q3 and since q3 emitter voltage is affected by it's base voltage then what is affecting it's base voltage?
At the moment I try to avoid randomly taking out parts and measuring them to avoid stress for the board and I need to preorder the parts needed for this repair so I don't have a quick replacement.
By the way I have a plan to do a recap using higher quality caps and I've also cleaned the pots and switches already. Also after the power amp is repaired need to check whats the deal with the vu meters and resistors.
Appreciate your input!
- Visual inspection - ok, except some burnt area near vu meters and extra 2.3k resistors added in series for vu meter + wires(why?)
- Initial cleaning ok
- Check the wattage draw to avoid any shorts - ok around 20W
- Check output voltage (dc offset) right channel ok around 5mV, left channel 2-2.5Volts
R7 14V: 14v
q1+q3 6v: -1.7v
q5 b -41.8v: -45v
q7 e 43.4v: 47v
q7 k 1.2v: 46
q7 b 42.8v: -1.2
q13 e -1.2v: -3.5
q11 e: 1.2v: -1.2
q5 b -41.8v: -45v
