Hi! Got my first Kenwood amp, and looking forward using it. Want to see if I like the sound of it or not. So far the unit works fine, but was clicking the relay really slowly. Was taking up to 30 seconds. Switching the relay for the new Omron (found recommendations on the old threads here). It does power up faster, but still takes just a bit longer than it should. Caps where replaced also. Does anyone know which of the transistors are the relay transistors? I see many people tell to swap them right away, since they go bad. Would be great if you could also point to the replacement part on digikey or mouser! Thank you!
