Recently picked up a KA-770D for $20 on my local Craigslist. I hooked it up and found the left channel (both A and B speaker settings) is virtually silent. (If I listen closely, I can hear it very softly). The sound out of the right channel sounds normal/good.
Here's what I've ruled out so far:
- Speakers - they work fine with a different amp
- Mono/stereo switch - doesn't change anything
- Balance knob - twisting to the right doesn't change anything; twisting to the left makes everything virtually silent (again, still very soft music coming out of left channel)
- A/B speaker switch - amp behaves the same way on B speakers as it does on A
- Headphone jack - works; matches what's coming out of the speakers
- Different inputs - all inputs produce the same result
- Muting switch - works as intended
- Loudness switch - works as intended
- Subsonic switch - not sure what this does, but doesn't seem to change anything when I toggle it
- Bass/treble knobs - work as intended
I used compressed air to blow the dust off the boards and out of the nooks and crannies and then sprayed out the switches and boards with deoxit. Now letting it dry for a few hours before I try it out again.
What else should I be doing as first steps here? Anyone have any idea what could be causing this problem?
Thanks for any input you might have! I attached some pictures in case there's anything glaring...nothing I've noticed so far.
