Kenwood KA-907 Volume Pot
Robayb
I have a scratchy Volume knob on this amp. Occasionally my right channel drops or is scratchy, when I quickly turn the volume high then low it usually comes back on.
So when I looked inside to deox - it does not look like a traditional pot....it has a small circuit board attached to a small plastic box housing, where I expected to see the pot. Does anyone have experience in this?
BTW - all the other pots are "normal" pots that I was able to clean, along with switches, but it didn't help.
The board is really just for connecting all the sources neatly. Inside the plastic housing is where you need to spray deoxy. 6 gang volume pot.
