Kenwood KD-750 Troubleshooting and Repair Writeup
Old 96er
I just want to share some of my knowledge and experience with my Kenwood KD-750 turntable as a way of paying it forward to those on here who have helped me along the way. I’ve had this turntable for over 20 years and It just recently developed the dreaded speed control issue.
At the end of last summer (2019) my KD-750 started having intermittent speed control problems where the quartz lock lamp would blink off and on every so often as it tried to maintain speed. The problem began happening more frequently to the point where I could only listen to my records for about 10 minutes before it would reliably fail to maintain quartz lock. I tried cleaning the speed control trim potentiometers on the circuit board with DeOxit, which initially seemed to help but neither would hold an adjustment.
logically, I replaced all the 40-year-old electrolytic capacitors with Nichicon KL. The problem corrected and the unit maintained quartz lock reliably for several months until February, when it started acting up again. This time, the failure mode changed. The quartz lock indicator would flicker and the platter would coast to a complete stop for a period of time and then start back up and try to maintain speed again.
At this point I was perplexed and overwhelmed by how I would have to troubleshoot this thing. There’s virtually no information out there about this somewhat rare turntable, besides the service manual, to go on. No convenience of a YouTube video of someone else repairing one. Now, I’m no stranger to a soldering iron or a multimeter, but the complex circuitry of this speed control board is no joke. Logic gate ICs everywhere! 17 of ‘em. Some of them out of production for years now.
Feeling like troubleshooting this thing any further was beyond my experience level, I took it to a local stereo repair shop. After waiting for about a month, the technician called me and said he was unable to find the problem and to come pick it up.
Determined not to give up on this beautiful unit, I began ordering ICs from eBay and China that could potentially cause the problem. The service manual has a pretty good troubleshooting flowchart. IC3 and 5 seemed the most likely culprits. Nope. I ended up unnecessarily replacing many other ICs with no success. Then, some better judgment prevailed and I finally got underneath and started checking voltages and comparing them to the service manual. Bingo, I found the problem. IC13 (TA7179P) is basically a bipolar power supply / voltage regulator IC that supplies +15V and -15V to IC10, a quad op amp. I was seeing the voltage on both sides of IC13 drop out to ~1V, which coincided with the platter coming to a stop. I hit IC13 with some freeze spray and the problem corrected briefly. I put my finger on the chip and that puppy was HOT!
Of course, the TA7179P chip is obsolete with no cross reference, so I found a new-old-stock chip for $5 on eBay and ordered it. It arrived this past Saturday and I soldered that puppy in almost as soon as I closed the mailbox. I was shaking with anxiety as I put the unit back together for a trial run. I plugged it in, heart racing as I hit the power button, and I pressed the start button. I was never before so grateful to see one little red light glow continuously and reliably, never to flicker or blink again! That one chip, IC13 was the culprit. I listened to my records on this beautiful machine, with zero malfunctions, for the rest of Saturday afternoon and all day Sunday. Steady as a rock.
I have another “parts” KD-750 with a different symptom, and I found that it also has a bad IC13 (TA7179P), for which I’m awaiting a new chip from China. The IC13 of this unit failed in a different way than my other unit. Instead of both rails intermittently going to +1V, the -15V rail is reading +1.2V and the +15V rail is giving +15V like it should. The symptom that this “parts” turntable has is that the platter spins at very high speed. Everything else checks out except IC13. I’ll update my findings when I get that IC replaced.
At this turntable’s ripe old age of 40+ years, maybe It’s likely IC13 may be a common failure point in these models since I have two that happened to fail. I’m sorry for the length of this wall of text, but I hope my findings can help someone else out. I spent many, many hours poring over the lengthy service manual and theory to get to this point. Thank you for reading and I hope this helps someone out.
Now you have me checking my KDs for that chip. Might need to stock one for the when it goes. Thanks for the post.
I know that at least the KD-500/550 and KD-600/650 have a different power supply configuration and do not use the TA7179P. I looked at the service manuals of those two models when I was looking for models with shared parts. Hope that helps.
Update:
I received the second TA7179P IC chip and installed it in my second “parts” KD-750 unit. I powered the unit up and it quartz-locked right away on both 33 and 45 RPM. I put the unit through its paces, switching the unit on and off and toggling the speed several times before playing records. All good, no errors. I’ve been playing records all weekend with this unit and it runs flawlessly! So, that’s two separate units with the same faulty IC. After 40+ years of service, I‘m curious if this is going to end up being the Achilles heel of these units as they continue to age.
When troubleshooting one of these units, remember that the troubleshooting section of the service manual assumes that the power supply ICs are functional. A failing power supply IC is not a possible cause in the troubleshooting flow charts, especially IC13. Strangely, it’s not mentioned at all. I shall note that a faulty IC13 can cause some of the failure modes that are diagrammed in the troubleshooting section, which would lead to other ICs as being potentially faulty. For instance, IC10, a quad op amp, receives its power from IC13. If IC13 is faulty, it can lead you to believe that IC10 is faulty as per the troubleshooting diagram when in fact IC13 is the underlying cause.
To test IC13, attach the negative (common) lead of your multimeter, set to volts DC, to terminal 3 (ground) on the circuit board. With a needlepoint test lead, carefully check the supply voltages going to IC13. Pin 7 on IC13 should give you ~+23VDC. Pin 8 should give you -24VDC. This rules out the main power supply. Now, test center pins (4 and 11) of IC13. Pin 4 should give you +15VDC. Pin 11 should give you -15VDC. Pins 4 and 11 are the +/- 15V supply rails for IC10 quad op amp.
Hope this helps someone.
This table will just be another one bricked by NLA chips. It is too common, unfortunately.
Fortunately, I was able to find NOS TA7179P chips on the auction site that came from China. Hopefully these will last another 40 years, but I did order an extra one for a spare. I do wonder, however, if that chip could be substituted with two discrete voltage regulators, one 7815 and a 7915. I thought about trying it, but just went the safe and sure route with the original chip.
There is one chip for sure that cannot be found, and that is IC9 (SM6415A-3S), which is the quartz oscillator/clock brain. If that fails, it’s pretty much game over without a donor unit. That doesn’t seem like a likely failure, though. Most of the chips on the board are 74xx series logic gates, most are NTE crossable. The four big 2SD586 motor control and power supply transistors are NLA and uncrossable, but failure of these seems unlikely since they appear to be pretty robust and they run cool. The auction site has some NOS of those. That being said, I’d say it doesn’t necessarily mean a death sentence if this turntable develops problems. At this point I know of a way to acquire every chip and transistor on the board except IC9. With my findings, the average stereo repair shop may not be able to fix or even troubleshoot one of these units, but with a little knowledge gained from research and studying the service manual, I know it is possible.
I just came into possession of a lovely KD-750 that has been recapped within the past few years. It keeps speed well, however, the motor is making a faint (but easily noticeable) ticking noise. This is very obviously from the electronic portion of the motor, as the bearing is silent when spun by hand. I wonder if this same chip could be the culprit
Yep, I'm pretty sure it's possible to wire up two voltage regulators on a piece of strip board and mount it somewhere in the case. It would look messy, but I don't see why it wouldn't work.
I'm back in my hometown getting my parents' home ready for sale. My brother has stored his KD750 here for about 30 years. We pulled it out and, though it spun, no lights worked at all. Then it quit spinning. It now acts like its just got a blown fuse. Thanks for this thread! He was going to take it to a shop and it looks like that will not be the option we want. I'll see what I can get from Vinylengine and then we may want to dig into this thing ourselves. It's much prettier than my KD500.
Thread revival. Just got one of these in for service. Same problems as listed above - no quartz lock, platter spins then grinds down to a halt. I'm getting +/- 28V on pins 7&8. Pins 4&11 show only slightly more than 1V. Several of the capacitors I've tested out of circuit have all measured well. I've ordered a replacement TA7179P and will update when it gets here.
Well, got my new IC and no difference except that upon first start up, the platter spun up really fast, then slowly died again. Now it will not spin anymore. I'm getting -21V on pin 4 and -21 on pin 11.
I bought my 750 in the 80s after it was discontinued by Kenwood at Crazy Eddy's, the same Crazy Eddy store that inspired 'Money for Nothing' - on 57th Street and 3rd Ave.
I'm still using it and fortunately everything works. I did buy another one but that one, which was rarely used, started having issues and as you said all the ICCs are obsolete and I couldn't source any.
Good for you!!!!!!
Is this the IC you are talking about?
Yes, that's the IC that ended up being the culprit in two different units of mine. If this IC in your unit is bad, I hope you are able to source a replacement and get it working again. That IC was difficult to find 5+ years ago when I fixed both of my KD-750s, which, by the way, have been working flawlessly since then. Good luck.
Yes I replaced that chip but still had a slight pitch control problem.The strobe was flickering.I noticed two adjustable trimmers inside the unit.Turned both of them clockwise just a tiny bit and the strobe light is now steady and she sounds perfect! probably didn’t have to replace the IC but now at least it has a new one in there!!!Thanks!
