Kenwood KD500 - armboard mounting templates
JPJ
AK Subscriber
I'm looking for a template to make armboard for a Sumiko MMT for my KD 500 if anyone happens to have one.
Or does anyone know if drilling a hole dead center of the armboard would work? Looks like one of the 2 armboards that originally come with the table has a center cut mounting hole.
thanks.
Sumiko Premier MMT Specs:
  • Effective length: 239mm
  • Overhang: 17.3mm
  • Mounting distance: 221.7mm
Install a blank armboard. Make a simple tonearm mounting gauge: cut a piece of thin hard cardboard, draw a line in it, mark two points exactly 221.7mm apart. Make a hole (7mm in diameter) centred on one of the marks. Insert a nail through the other mark. Put the hole over the spindle and use the nail to mark the location of the tonearm mounting hole.
  • Overhang: 17.3mm
that's amazing, thanks.
do you know the exact diameter of the hole I should drill in the armboard?
thanks.
got yourself a kenwood finally? Good on you.
Don't forget to oil the motor, it makes a world of difference.
https://liquidaudio.com.au/kenwood-kd-500550-turntable-motor-service/
^^ A guide on properly lubing the motor on the unit. your platter should be up to speed in 2 seconds flat, if not its time to lube the motor.
  • Like
Reactions: JPJ
