Kenwood KD67F question
cunningr
Well-Known Member
Hi,
I have a kenwood KD67F turn table, I have had it since it was new. Pulling my old gear out to put back in use. Can someone help with a needle stylus or cartridge solution? Not sure what is compatible, did some searching cant find anything concrete on compatibilty.
Thanks.
What cartridge is on it now? It must be compatible enough since you used it, and very likely it was the one that came with it when you bought it. It appears to be a linear table, many of which were P mounts, and if that is the case, all usable cartridges should be compatible. I'd buy a new stylus for the cartridge and leave it at that.
For reasons that elude me, there seems to be a current fixation on compatibility, which, to be blunt, is ridiculous. In the 70s, cartidges were getting more and more compliant, and many of the arms on older turntables and most mass market tables were massier than ideal for such cartridges. But no one makes high compliance cartridges anymore, and most current arms are less massy than the old blunderbusses, so almost all combinations are compatible enough (actually, problems are more likely to crop up with people using lower mass arms and less compliant cartridges, though the problem will be a very light sound, lacking in bass, rather than the arm bouncing up and down and the woofers blowing).
Thanks for your reply. It is the original cartridge in it. So basically you recommend a new stylus only. I appreciate your input. It was produced in late 80’s, is there a vendor or brand that you can recommend?
I am asking questions because not sure what is easiest or needed to rejuvenate the turn table.
Thank again for your reply
Take a picture and post it if you don't know the cartridge model. Without knowing what you have, we can't suggest whether it is worth seeking a new stylus, or whether it would be better, or cheaper, to buy a new cartridge.
Ok it has the kenwood cartridge that came in it, it is a T4P cartrigde after looking at it closer I think the stylus is missing. I gave her a good cleaning finally too.
That makes it easy - any P mount cartridge will fit and work as intended (obviously you need to remove the locking screw and then replace it (and the nut, if there is one, and if it came out). All you do is pop it out and put the new one in - no adjustments needed. There is a P mount version of the AT 3600 which ought to be under twenty bucks that is surprisingly good.
The Kenwood in there might be fine with a stylus replacement, and if you simply google the table model you should be able to find it.
OOPS - it occurs to me that I am assuming that the arm is a T4p arm. If it is a standard arm using a P mount cartridge in an adaptor, if you change cartridges but the new one is still a P mount, and you just put it in the adaptor, you ought to be okay, but I can't speak to how well the cartridge was aligned to begin with.
Just to close out the thread I ordered a new T4P cartridge. So hopefully that will square up the TT.
