In my quest in finding affordable high power Kenwoods, I’ve been curious on the late 80s KM/KC rack series.
I picked up a $20 KC-209 and updated it with the Basic C1 updates. You can read about it here. I was looking for a matching power amp.
I’ve read most of the posts of the KM-10X (125 w/c) and KM-20X (150 w/c) power amps on AK. Seem like cheap, reliable power. I think the major differences are the face plate and power meter to match the KC preamp. I think they are all basically the same.
Here are a few discussions i thought were interesting. I'm sure there are more.
@dognut posts this.
@himniok even talks about the KM-209 here.
@davidro post
@Roadrash wasn’t impressed
@theophile always has nice things to say about these power amps. These are almost like a “gateway drug’ amp to the Basic series and other Kenwoods up the food chain.
I finally picked up a $20 KM-209 on ebay as a parts unit.
Specs from HIFI Engine:
Checking a few things before powering up the amp:
dirty
7amp fuse is good and correct size
corrosive glue on PS caps look like a problem (or going to be one in the future)
dirty
Sheet metal chassis and cover is very thin and bends easily. But works.
no one has been underneath. You need to cut away some tabs to access the bottom.
After a quick bath, I powered up on DBT and bulb dimmed and relay clicked
Display doesn’t work. LED power meter works. I replaced the display bulb from @dlucy HK 330B restore (I’m also working on a 330B) and now have a working KM-209 with working display. About 10 minutes of work.
Scope signal looks fine
Powered up on AC mains
DC offset is fine at 2.3mV/3.0mV
Hooked up a test setup (and KC-209) and played music
After an hour checked bias 21.0mV/23.1mV. Factory says 9-18mV so I’ll adjust that.
My $20 power amp seems to work. Going to remove some glue before critical listening.
Looking at the schematic, only an input coupling cap and a couple resistors in the signal path.
I updated a KM-208 for a customer with a pair of WIMAs. Might do the same here.
Here are a few pics since everyone likes nudes.
Not sure what I’ll use it for so stay tuned...
@dognut posts this.
@davidro post
- Power output: 150 watts per channel into 8Ω (stereo)
- Frequency response: 5Hz to 200kHz
- Total harmonic distortion: 0.015%
- Damping factor: 35
- Signal to noise ratio: 120dB
- Dimensions: 440 x 133 x 269mm
- Weight: 8.8kg
dirty
dirty
