Kenwood KR-10000 II - Finally Relamped to LEDs
TheWindyCity
Greetings all! With much time on my hands due to he current world situation, I decided to re-lamp my Kenwood KR-10000 II one final and last time, using LEDs. I have re-lamped this receiver multiple times since I have owned it. We have it on pretty much every day for more than 8 hours! I previously put dropping resistors in the lamp supplies to make the bulbs last longer. I was getting about 5 years out of the incandescent bulbs this way.
The receiver has two lamp power supplies to drive 21 incandescent lamps in total. One supplies 8 volts AC to four bayonet style lamps for the meters. Another supplies 8 volts DC to seventeen 3mm grain of wheat lamps.
LEDs:
After testing, I used these 12VAC 180 degree, 2700K lamps from Superbright LEDs for the meter lamps. Power to the lamps was at about 9 VAC, and the brightness level was perfect for the four meters.
For the remaining grain of wheat lamps, I went to eBay searching for a 3mm warm white LED, and found a 3500K, 3.0 V, 20mA, 120 degree angle LED in a 3mm package. To this, I added a 270 ohm, 1/8 watt dropping resistor.
The conversion took me about 2 weeks from procurement to finish. I am really pleased with the light level and color. It looks great lit up at night in the stereo cabinet. Now I don't have to worry about going back in to change lamps any longer.
In process -- a mix of both
How I modified 17 of the 3mm LEDs
Old and new meter lamps
Completed modification:
LEDs:
Nice work! On the meter lamps, it looks like yours uses the same "globe" style lamps as a KR-2400 uses for the dial. Did you have any flicker with those LEDs?
No flicker at all, even with the "Dim" button engaged, although that no longer has an effect because the dim circuit dims via a diode.
