LAylEE
Hi AK community,
My Name is Lajos and this is my first post.
Your community helped me a lot with my other receiver KR-5150 in my living room, I appreciate it a lot.
I was unable to resolve an issue with my new receiver Kenwood KR-3200 in my working room.
I'm new to vintage audio systems, and I bought this KR-3200 knowing that it has issues with the tuner.
So, when it came I cleaned very well all the contacts, buttons, pots.
When first powered on, the main AMP worked great and the sound was pleasant, when listening from aux input.
The issue is the tuner, there is no AM tuning at all, it is just muted, and on FM I can tune in on strong local stations, but stereo lamp never came on(Checked the bulb and it's fine) and the Signal meter is not swinging.
I checked all the transistors, resistors and diodes on tuning PCB.
Everything looks fine, exept I found two of the diodes being dead Dg14 and Dg12(1N60 Germaniums). Replaced them with BAT41 Shottky diodes.
So right now, AM still nothing muted(signal meter not swings), FM signal meter swings, and stations can be tuned(only mono, stereo never locks in), but signal meter works wierd.
When I tune in to a strong local station(Using a T dipole FM antenna connected to 300Ohm) let's say 102MHz, where the sound is the clearest the meter is on 1, but when I tune to around 102MHz(up or down doesn't matter), the meter swings to almost 4.5-5, but in that case the sound is really faint, even on max volume you can barrely hear the sound.
Pressing stereo or mono button doesn't do any difference.
I'm hoping someone here can give some advice on what to check next, or if someone had this experience.
Schematics of KR-3200:
https://www.vintageshifi.com/repert...ge.php?pdf=Kenwood-KR-3200-Service-Manual.pdf
Video demonstration of FM tuning(in order to watch video, you need to download it):
https://www.dropbox.com/s/f9gotp6l9ul3eff/Kenwood KR-3200 Tuning issues.mp4?dl=0
Thanks in advance!
Lajos
Thanks in advance!
Lajos
