Hi all, so far I have learned a lot on this forum. I hope one of you can help me with a weird problem with a Kenwood KR-4070 receiver. I recently bought it, without knowing if it would work or not. Luckily most of the time it does and when it works it sounds really good (both on tuner and on line signal). However, after a few minutes, a loud hum comes up slowly on both channels, reaching a maximum after a few seconds and which is not affected by lowering the volume. After the unit is switched off, the hum almost always has disappeared after a few minutes. When connecting the speaker output signal to a 8 Ohm dummy load and turning up the volume of a 1000 Hz test tone, the shape of the sinus appears clean until it almost reaches clipping level. What happens next is that the sinus breaks up and only the top halve of the curve is present (see pictures before/after). This happens on both the left and right channel. I am not a technical expert, but it seems like there is some problem in one of the +/-40 power rails in the power amp module. Does anyone have a clue what may be happening here and how I may proceed? My best guess for now is to measure all power caps in the power amp module and to replace all caps that are out of spec. (BTW: the notoriously bad on/off switch seems not to be the culprit here: there is always a stable voltage coming from the main transformer). I really would like to get this Kenny working again, preferably without having to recap the whole thing… Any help is much appreciated!
