Ylli
I think you got the leads improperly identified.
14.2 volts collector
2.1 volts base
1.5 volts emitter
would be exactly as expected.
When trying to listen to stereo, you get only mono, but you get it out of both channels, correct?
I am suspecting a bad Lc4. Lots of turns of very fine wire - not unusual to have these fail. Would be best to have an Oscilloscope, but let's see what we can do with your DMM set to the AC range. If you have a scope, let me know, otherwise set the DMM to AC, and connect it across the primary of Lc4 (in parallel with Cc8. What do you get for an AC voltage?.
2.1 volts base
1.5 volts emitter
