Hi all, I have been working away on a Kenwood 5400 with one bad (left) channel: there is a variable amount of distortion at higher volumes. Pots and switches were checked and cleaned, power caps were measured and seemed OK (for now). The signal going in the power amp is clean: I measured a 100 Hz test tone going in via Aux at PCB points 1 and 2 (from schematic) [photo #1 and #2]: both channels appear undistorted and stay equal at different volume levels. However, measuring the power amplifier signal going out [photo #3 and #4] there is increasing clipping on the left side that increases with volume. I took out the power transistors and other main transistors and caps in the signal path (marked with green star on photo #3): when not within spec they were replaced. The 2SA627's were both functioning, but their measured hFE's differed quite a bit, so I decided to swap their positions to see if the distortion would change channel–which it did not. The best clue that I have is that there should be still another component in the left signal path that is bad, so I will go over these one by one.
Is this a logica approach? If one of you has another clue or suggestion that would be much appreciated! Have a great day!
