tusntuk2
I'm rebuilding a Kenny 5600. Original description was "one side out", and all the lamps are out. This improved some with deoxing the controls, but there were two anomalies. The FM had terrible distortion on one side, and while checking a signal thru the AUX, the Treble control, when turned to full open, suddenly made a weird high noise in the headphones. Other than that it seemed to be sort of working.
Inspection revealed a badly burned PS board, a documented design problem. I totally repopulated a second board and installed it. (that's a real bugger, boys, I don't recommend it for the faint of heart!) I recapped the AUDIO board, and changed diodes and transistors for the relay circuit and the bias circuit.
View media item 21721View media item 21722
Passed DBT, to my delight. FM shows same weak side, bad distortion, so I hope thats in the FM. I switched to AUX and things sounded great! For a minute. I had powered back up with all controls down, so I was testing controls. Bass, fine, Loudness, fine, Balance, fine, Treble - was working until about 4 o'clock on the dial. Heard a tiny pop in the headphones and that sudden high pitched noise when I went to the max on the control. The DBT glowed bright and I quickly turned the Treble control back. Fuses did not blow, the noise stopped, and the amp sounded great.
What do you think causes that sudden surge at full treble? As a musician, I would equate it to Feedback, that sudden squeal. What is happening to the amp? Some kind of oscillation?
How do I find it, where do I look, what can I measure to get off the hook?
As usual, your fine help and insight is greatly appreciated!
schematic available
schematic available
