Hi all. I normally run a Kenwood KR 6050 with an Elac 10H turntable. Previously I was running a Pioneer PL115D with the Kenny. I've always battled with feedback and rumble issues, and tried a number of various isolation methods, all to no avail. I had chalked this problem up to my rental house and its cheap, wham bam 1970s or 80s 2x4 framing, and our living room being up on the second floor. This issue has lead to my KG4 woofers "pumping" like crazy, especially when volume is up. They do/did this with both turntables. The Elac is slightly reduces this some, but now instead of the hollow, wooshing sound the Pioneer used to make when the stylus hit the record, I get that nice, loud idler wheel rumble.
Today, I picked up a Marantz twenty two for a cheap, got it home and cleaned up, and set it up on top of my Kennwood receiver to hook it up to my system for a test drive. Oddly, this has solved my rumble issue. I'm baffled...could it be possible that my receiver requires isolation? Have I essentially isolated the Marantz by putting it on top of my Kenny? Nothing else in my setup placement wise has changed. Could there be something wrong with the phono stage of the Kenny that is causing this rumble?
I'm pumped not to have to listen to my Elac howling like a banshee when I listen to records, but long term I prefer the Kenwood to the Marantz. I'll try switching the placement of the receivers tomorrow to see if that solves it. Just thought someone might chime in here if they could think of anything that may be wrong with the Kenwood that would cause this to happen.
