Kenwood KR-6160, Oh MY!
birchoak
Hi-Fi Nut
I've wondered about this model for some time and finally bought one. For those who don't know, the KR-6160 is a 1971, 55 watt, cap-coupled receiver with an engraved face plate and triple tone controls. It's quirky looks endear it to some and repel others. I wasn't sure which camp I was in until I turned it on.
This is the best amp or receiver I've heard bone stock. I'm sure this was a fluke, some temporary gift from the fickle hi-fi gods, but it delivered the goods with 50 year old parts. I often struggle to qualify what I hear when I listen to a given hi-fi system, so I'll just say this: I began digging into my music catalog, playing everything from Abba to Lenny Kravitz. I could not stop listening to this receiver and had to be dragged upstairs to dinner.
The acid test of a receiver's durability is whether or not it can survive a recap by yours truly. Most of the time things work out--a few dramatic moments, some potty mouth, questioning why I was born, etc.--but then the thing works again, with new caps. I was very nervous about recapping this and checked my work after just about every cap, with the DBT and by playing music through speakers.
I did lose FM and AM. I later found a solder bridge on the PRE board. When I removed it I had one channel back in FM, but not the other. I think I shorted one of the driver transistors on that board. A shame as this thing pulled in FM as good as or better than anything I have, with no antenna attached, in my basement.
But everything else still works and the new filter and output caps haven't changed the sound. The amp card was quite easy although needle nose pliers were required to re-attach two spade connectors on the front.
Is it the perfect receiver? No. The amp card socket is made from a clear, hard plastic, and mine was broken at one of the screw hole ears. I fished all the pieces out and attempted to super glue them back together, several times, but found no lasting joy. Finally, I was able to get the pieces to stay together long enough with super glue to squeeze two-part epoxy from a syringe over the fracture. It seems to be holding and I've since pulled the amp card and re-inserted it with no further damage that I can see. This isn't really a deal breaker--as long as the socket will still mate with the card you've got music, and there's so many wires feeding it that even without screws the socket isn't really going any place. It's just not something you want to happen in your receiver and I wonder why Kenwood didn't spec a more robust plastic, like JVC, Fisher, Hitachi, and, um, Kenwood did (in the KA-7002) in similar amps with amp cards that plug in.
Something broke off in the Alps-branded bass pot, allowing the wiper to travel in a continuous orbit, with no stops. I pulled the outer pot shield off, saw that accessing the inner pot might destroy the entire thing, and put the shield back on. I don't typically adjust midrange, so I swapped the bass and midrange pots and bass was back in business.
The volume pot is comically undersized and has absolutely no physical resistance when you turn it--it's like turning the knob on a child's toy radio. But oh, the magic that that knob unleashes...
Aside from one trim pot on the PRE board, I see only two trimmers on the amp card. I imagine these adjust center voltage, and/or bias current. If this is anything like the JVC 5551, you can dial in center voltage, or bias, but not both unless the planets are aligned and it's Tuesday and a magic fish high-fives you. I haven't touched the trimmers and I'm really, really trying hard to not mess with them at all as this seems to release magic smoke or at least a very long trip down the amp adjustment rabbit hole. With output caps my speakers should be safe from DC, and unless I install new TO-3 devices or drivers, I think I can leave those trimmers alone. I'm still smarting from losing one channel of FM :(
If folks are interested I'll take some pics and post them. BTW, the speakers are newly-restored Polk Audio Monitor 7's and I don't think I've experienced better speaker/amp synergy. I don't have a good handle on the audiophile lingo, so let me just say I was singing along to Journey's Greatest Hits, not something women and children should hear and fortunately a rare occurrence. As soon as I finished dinner I ran right back to the bench to do more listening.
Kenwood made very good amps and receivers, I personally think they are under-appreciated. Not complaining because that makes them less expensive to acquire these days! I picked up at KA-80 amp new back in 1982, and I don't regret that at all. Better (cleaner) amp than nearly everything else I've heard, has some incredible damping factor and very good specs -- and sound!
As far as brittle plastic fitting goes, I suspect that not only did the engineers not think that someone would be still using that amp 50 years later, but that the degredation wasn't known at the time. Lots of "miracle" plastics have turned out to be fairly unstable after decades.
You can buy replacement for this item. look up
PCB card edge connector in ebay or computer parts supplier.
-They'll probably be dual sockets but just wire in the one side will work
I've had the same problem in a yamaha of this same vintage. I was concerned the plastic was brittle internally and would eventually lose contact with the pcb. Replaced and good to go.
The KA6000 also has this item.
Really isn't as bad as you say. I've never had an issue.
So now that the honeymoon period is over, how is the unit working out? Its great when you come across a bone stock behaving unit. And its great when you can appreciate the value of that!
Since you're going down this rabbit hole, Have you checked out the Kenwood TK units?
Ha ha, rabbit hole is the right term for this. I found another TINY solder bridge on the PRE board and both channels are back in FM.
The thing has survived my recap and continues to sound excellent---commanding, full-bodied sound and FM is excellent, much better than I expected from something so old. The push-buttons feel very good and solid and having two AUX inputs is nice. Thank you for the card edge connector tip--I figured that part was unobtainium, had no idea you could still get them.
I have not checked out the TK units--those are even older, right? I've had some tough times with the really old stuff---primitive volume pots that won't track equally, weird RCA jacks that won't accept modern cables, etc.
Jinx! Turned on the 6160 this morning and have that ocean sound---I'd say a transistor has gone bad. I thought I replaced all the 2sc458's but I guess not! I usually knock on wood when I praise something (truck, health, amp) but neglected to do so this time. So my bad.
I got one in a pile of broken stuff, assumed it was a ~13wpc tiddler and that it was broken.
Wrong and wrong.
I'm a fan of the funk, and it sounds great. Did you bump the power and output caps? That's a huge 2000uf cap.
So sad to hear about @birchoak , I didn't know him personally, but I was following this thread as I also have a Kenwood 6160 (blessedly in mint condition). Also, he was the author of the great post here... https://audiokarma.org/forums/index.php?threads/songs-that-stab-you-right-in-the-heart.827624/
Which showed just what kind of human he is (among many other posts as well)! I've lost many family members in the last 6yrs and most regrettably, both my parents and my best friend (those of you who know, it's like being untethered from the world). This particular post has helped me to remember and grieve the ones who have gone before. In these crazy times the world is going through, let's remember to not take for granted every day we have upon this earth and most importantly, treat each other with love and kindness... Rest in peace fellow AK'er, and wish I could've known you personally.
Tengo un Kenwood KR-6160 , es uno de mis favoritos , contra marcas como marantz y SANSUI ,es increíble la calidad de sonido que este modelo tiene, muy muy bueno receptor Kenwood
