benjaminlee
I recently purchased a Kenwood Kr-6600 from a man on facebook who said his relative used it for a while, then it sat in a barn for a while.
When I powered it on for the first time there was no sound at low volumes, and a faint sound close to max volume. I have since worked the dials and switches quite a bit, and sound does come through now, though the right channel is a bit weaker than the left.
Not long after I powered it on for the first time, the relay started to disengage after the amp was on for a few moments. After that, the relay wouldn’t engage when the amp was powered on. A day or so later, the amp will turn on, relay will engage, radio seems to play fine, but after about a minute of being powered on the relay will disengage, sometimes toggling back and forth quickly.
The only other notable issue, is when I tried to send a signal through the aux input, the relay would disengage and stay that way. I was able to use the tape play input to get sound, though after a few minutes of that, the relay shut off again.
I figured going into this that it wouldn’t be fully functioning, at least not until it gets a good cleaning, but I’m not sure cleaning is all it needs. Unfortunately I don’t have a guitar center anywhere near me, or any store that carries deoxit, so I ordered a can of d5 and f5 which will be here Friday.
It may be that I am just describing what occurs when pots/switches are really dirty, but I figure I can’t know that until the deoxit comes. The input selector is really tough to move, so that may be the culprit, though even with the volume at 0 I still hear pops and crackles. I’ve been reading countless related repair forums, but this is my first vintage amp and I could really benefit from some more direct guidance. Hoping someone sees this and is able to help in some way, thanks for reading!
Edit: Just tried playing through aux input, seemed to work fine for about 5 minutes, then relay started to flip off and on repeatedly.
