VonKuhn
Hello, after weeks of searching I am finally desperate enough to post a question and look for help. Recently I got a Kenwood kr-7600 in great condition to repair, just a bit dusty, and no sound at all. After some searching, I found a transistor (2SC1419 NPN) surrounded by dark spots on the board it was attached to. After replacing it and another close transistor, the amplifier sprang to life, but the transistor was getting very hot, along with surrounding resistors. After doing some voltage readings, I found that the transistor had 24v on the base, around 34v on the collector, and around 23v on the emitter. The data sheets* say the voltage is within specification for the collector and emitter, but not the base, which has a max voltage of 5v. What has gotten me stumped is that the power coming to the base is coming from a resistor attached to two large caps at 54v. The resistor is rated a 2.7k in the schematic**, which it is what it is. I tried upping the resistance, but the voltage stayed the same. What am I missing? If you have any questions, please feel free to ask.
Transistor datasheet:
*https://html.alldatasheet.com/html-pdf/270779/SAVANTIC/2SC1419/384/1/2SC1419.html
kr-7600 manual and diagrams:
**https://www.manualslib.com/manual/948987/Kenwood-Kr-6600.html?page=17#manuals
