Hi, and thank you for a great forum with lots of awesome discussions!
I picked up a Kenwood receiver from around 1998 for 25 dollars, including Kenwood speakers. Now, the problem is that there is distortion in it. But it seems to be just the first minute. At first there is no sound, and it gradually becomes more and more sound, but it is distorted. More distorted in the left channel, but some distortion in the right channel as well. When I connect a second pair of speakers, the distortion is a lot worse. Sounds like clipping, but it happens regardless of input or output volume.
It was really dusty inside, I have vacuumed (I know, maybe not the preferred method), and cleaned up the whole main board, both sides, with something called electronic cleaner. Didn't help. There was some nasty salt-like layer almost over the whole thing, I think it could be dust that has dissolved in the cleanup and then settled as a thin layer. I got rid of most of it with q-tips and a paintbrush. Or could it be a cap leak maybe? Although I haven't found any apparent caps that is bad, from the looks of it.
I am thinking it is the power supply caps that could be in need of replacement, especially since it goes away after a while.
Or could it be something else?
