Forgive my ignorance: but what is the difficulty with it? Desoldering and replacing them doesn’t sound that complicated. Time consuming yes, but what am I not following? Appreciate the adviceA complete recap of the KR9600 is a challenge, even for an experienced pro.
I see. I’m in the process of finding the right workbench to set up a solder station on then I’m going to assess where to go from there. I’m tempted to just fix the offset and let it ride but considering the parts in this unit that are unobtanium I am worried shortly after some regular use, something would fail and fry the trio packs or something to that effect. Outside of recap, the triac switch mod looks within my abilities too and is the only mod I wish to pursue at this time.Access is difficult, and a good rebuild involves more than just cap replacement.
With regard to my quote about the charge, I didn’t mean that in a sense that I do not value the work they do. I understand the time it takes both in present and from past experience. I just would rather keep that cost to a minimum and pick up the skill myself. Learn something new! Sounds fun.Quoted: "Just can’t stomach a $500+ bill from a shop, and I’d like to learn this skill so that I can continue to restore these units."
My response is more a generic one and not directed your quote, but it looked like a good segue for my thoughts on this subject.
When you get immersed in this hobby, you'll quickly understand why shops charge what appear to be exorbitant rates. Usually, when someone posts an exorbitant rate, the EE experienced will jump in and say "That's too much!". Yeah but ...that's because they have experience and know exactly where to look for the issue and have the skills to fix it. Experience/education doesn't come cheap and neither does a brick and mortar lease. As an anecdote, I can earn more per hour at In & Out Burger than I can performing restorations ...seriously. But money is not why I do it.
I think it's great you've decided to embark upon this hobby yourself. As @SicMan told me early on -- something along the lines of -- you won't soon forget this after you get it up and running. New skills breed confidence.
Relative to your query regarding buying a cap kit from the auction site...you'll learn more if you order them yourself. It'll force you to reference what's already on the boards. The more you see it, the more familiar and comfortable you'll feel when you repair it.
You'll soon find that a full recap/resto of a KR9600 is close to what you encountered with the Pioneer. @spark1 has given a great step by step approach to follow on the restoration process on post #26.I see. I’m in the process of finding the right workbench to set up a solder station on then I’m going to assess where to go from there. I’m tempted to just fix the offset and let it ride but considering the parts in this unit that are unobtanium I am worried shortly after some regular use, something would fail and fry the trio packs or something to that effect. Outside of recap, the triac switch mod looks within my abilities too and is the only mod I wish to pursue at this time.
The boards on this look easier to access than the pioneer qx949 I’m battling what to do with, so I feel like this is a better one to try servicing first. I will take your advice and be very methodical about it if I proceed. Just can’t stomach a $500+ bill from a shop, and I’d like to learn this skill so that I can continue to restore these units.
