Locomotive
Hello everyone. I an having an issue with the L-07C I bought recently. Everything sounds great thru the AUX and TUNER inputs but after buying a Turntable (KENWOOD KD-12RB) and a bunch of records and moving a lot of heavy things around in the garage and hooking everything up with a severely injured back the LEFT CHANNEL INPUT terminal on PHONO 1 does not work at all. The turntable I bought works properly also through both channel output wires the L/H WHITE and R/H RED wires and I also tried both ground wire terminals separately.
My KENWOOD KX-79CW Cassette player sound output is much lower than the AUX and TUNER output sound levels also thru this KENWOOD L-07C PRE-AMP I bought.
I am going to look inside it for any problems and I would like your opinions on what to look for etc. I'm going to take the cover off in a little while to check things out and I will state my findings and maybe take some pics. I did read a lot of the AK pages about these Pre-Amps. I might get stuck with this L-07C so I would also like your opinions on if I should get another L-07C or the L-07C II Pre-Amp and why/what are the differences?
It sounded fantastic thru only the right channel because the Bass really came alive thru my Kenwood L-09M Amps and Kenwood MV-9D and MV-5D speakers which usually sound really bright using my Kenwood CD-324M CD Player or my Kenwood L-07T Tuner. Your help will be greatly appreciated. I can't wait to hear it with both channels working properly playing some of the
awesome old Rock records I scored on CL.
