? My amps work flawlessly and they do not generate much heat. Thanks for your reply!Being a new member of the L-series from Kenwood/Trio, I need to know if the Trio L-05Ms (the Japanese 100V version) have the same reliability (susceptibility) problem that leads finally to oscillation and self destruction. I do not have a service manual (maybe another member of AK is kind to send me a copy via e-mail?).
The outputs of these amps are NEC 2337/1007 (without the A!), the same as in Trio/Kenwood L-07M II? My amps work flawlessly and they do not generate much heat. Thanks for your reply!
I picked up a pair of L07M Mk1 today. I plugged each one at a time to my 100 watt dbt and they relay just clicked on and off and light is just bright. Should I use a 150w bulb instead? Or do these amps have a soft start circuit and do not likeby the way, my L07ms performed EXACTLY the same after a rebuild- the distortion was still below 0.003% at full power and the bandwidth was beyond my computer based sweep withing 0.01dB.
I guess. It started almost 16 years ago.This thread has as many lives as a cat...
if you let me ride that sweet Beemer, I will tell you all you need to know about DBTI picked up a pair of L07M Mk1 today. I plugged each one at a time to my 100 watt dbt and they relay just clicked on and off and light is just bright. Should I use a 150w bulb instead? Or do these amps have a soft start circuit and do not like
DBT? Fuses are are intact on both units.
defective by design, #anti-longevity?and this is the fourth one in six months that I've worked on that has oscillated itself to death
