I used them with two Sanyo TSD-N06U step-down transformers. The owner opted for the 100v version over the multi-voltage version because of the external power supply provisions. He has his eyes peeled for a set.Really fantastic. I see these are 100V Japanese market models- were you able to convert them to 120V, or do you use a large step down transformer?
Thank you!Fantastic Work @Connor G
Really inspiring
I am growing really fond of the L-07Mii and L-07Cii combo.
Thanks for your kind words!Damn, I can't believe how little love this thread got. I'm sure you've heard it a million times, but amazing work. You are a huge inspiration to me, I hope to be able to do work as half as good as you one day! I wish you did a video on these!
Yes it should be fairly straightforward to replicate these power supplies. The trigger circuit is fairly rudimentary. From memory, turning the L-08M on sends a small voltage to the power supply that engages the output relay inside. I have the voltages and pinout scribbled down somewhere around here.@Connor G; do you think it would be possible to clone the external PS units, or is the control circuitry the stumbling block?
I’m also curious to know what the owner thought when he added the PS units - did he give you any feedback on the sound quality?
Correct. The L-08PS was only designed for the Japanese market 100V L-08Ms. There could have been many reasons for this, not the least of which being the fact that the L-08M was not sold in terribly large numbers. They likely wouldn’t have recouped the cost of manufacturing the L-08PS for international models, so the idea probably died early on.I thought the L-08PS is only compatible with the Japanese version? I have a European version of the L-08M, and the connection slot is blanked.
Very much a shame. Many recherché high end pieces from most of the major players were exclusive to the Japanese market - never to see the light of day anywhere else.It's a shame, I've always considered the visual design to be one of the best of the 80's, guess it was a little too 'out there' for the time, I'm guessing the preamp sold even less, with how much rarer it seems to be? Which I can actually understand, some strange design choices there, but a very good sounding pre.
I have six L-08PS units. They can be linked together to provide the L-08M with an immense power capacity. But I have to be honest—if you already have a pair of L-08Ms that have been perfectly restored, connecting them to the L-08PS will actually have a negative effect. The bass becomes overly heavy and sluggish, while the treble turns tense and strained.It's a shame, I've always considered the visual design to be one of the best of the 80's, guess it was a little too 'out there' for the time, I'm guessing the preamp sold even less, with how much rarer it seems to be? Which I can actually understand, some strange design choices there, but a very good sounding pre.
How on earth did you manage to acquire 6 !I have six L-08PS units. They can be linked together to provide the L-08M with an immense power capacity. But I have to be honest—if you already have a pair of L-08Ms that have been perfectly restored, connecting them to the L-08PS will actually have a negative effect. The bass becomes overly heavy and sluggish, while the treble turns tense and strained.
I think the performance might be limited by the power supply capacitors in the L-08M itself. Although the transformer capacity has been increased, the power filter capacitors remain unchanged. The L-08PS does not increase the capacitor capacity; it still relies on the capacitors in the main unit for filtering.How on earth did you manage to acquire 6 !
What you say is very surprising. I have a Japanese pair that are currently on their way to my friend who is going to restore / upgrade them. They will need a new mains trafos for UK 240v, so I was thinking why not just get higher VA rated ones in lieu of using the external PS units (which I don’t have anyway).
It depends on the type of speakers used. The L-08M is particularly well-suited for driving large, bass-reflex speakers. Sigma drive is very effective with these types of speakers, providing a level of damping that most amplifiers struggle to deliver. However, when paired with sealed-box speakers, the results can be somewhat disappointing.Understood thanks. So upgrading the filter caps will be an option . . .
Can I ask, have you compared the L-08M to any well regarded modern amps?
