Remote trigger cables
I just found this post here on AudioKarma titled- Kenwood L-07C to L-07M remote trigger cables.
On 01-16-2009, 04:32 PM Calabashak wrote-
Thanks EW. For other's reference, the plug is a DC power plug, 5.5 MM OD x 2.1 MM ID. Current Parts Express SKU is 090-477 (or 090-478-FOUND OUT 090-478 I.D. ON THIS PART IS 2.5mm & should be 2.1mm DIA. THRU AK RESEARCH)
01-16-2009, 05:18 PM redcoates7 wrote this in the same thread-
You got it! The circuit is really simple too...all you have to do is close the contact between the inside pin and the outside conductor and the amplifiers power up...so essentially there's a relay inside the L-07C that close and completes a circuit which in turn activates a second relay in the L-07M that powers em up...no voltage is sent from the preamp to amplifier, so in a non-Kenwood preamp system you could rig something up with a simple toggle switch.
Originally Posted by calabashak View Post-
Recently picked up a Kenwood L-07C to go with the L-07Ms. The monoblocks can be turned on via remote cable from the preamp; any ideas on what/where I can get replacement cables?
The little I know about these is that the socket on the monoblocks looks like they accept a female terminated cable; based on some googling modern trigger cables appear to be different - male 1/8" plugs (Radio Shack Part No. 42-2420 for example).
Also posted in the same thread by calabashak - Thanks all. In the last 2 hours I was able to snag some equivalent plugs from the local Radio Shack (their Part No. 274-1569) and whip up some cables. Works fine.
So I assume these should work on the L-09M's also. Now if I can just find something equivalent to use as the special locking RCA input terminals on the L-09M AMPS & my mission will be complete.
I FOUND MORE INFO DIGGING AROUND WEBSITES, SERVICE MANUAL AND OTHER AK THREADS BELOW-
FROM-
http://products.pacparts.com/kenwood_e30_0594_05_remote_cord_l07m_1101798920.php
Kenwood Part #: E30-0594-05 Remote Cord L07M- No Longer Avail Ka8300 L09M ?
Availability: Not in stock, Usually ships within 2 to 4 days* - Price: $37.00
FROM-
https://www.partstore.com/Part/Kenwood/Kenwood/E30-0594-05/New.aspx
Availability: Currently out of stock but available as a Special order, Order Now - $32.11
http://www.parts-express.com/21mm-x-55mm-power-plug-to-screw-terminals--335-370
2.1mm x 5.5mm Power Plug to Screw Terminals
Brand
arts Express
Overview-This solderless DC plug is ideal for field-terminating power cables. Connecting the plug is simple and easy, and the connection is secure.
Highlights-Ideal for field termination and perfect to keep in the toolbox
Common 2.1mm x 5.5mm x 9mm connector
Allows for solderless termination of DC power cables
Terminals accept wire sizes up to 16 AWG Part # 335-370
Weight: 0.02 lbs
Based on the polarity marking on the overmold, center is (+) positive.
If you need center (-) negative, you an simply switch the wires.
Product Details-2.1mm x 5.5mm Power Plug to Screw Terminals
Quickly and securely terminate bare wire with these barrel plug without soldering. The barrel dimensions are common 2.1 mm x 5.5 mm x 9 mm making them perfect for use with CCTV cameras, amplifiers, and projects.
Note: This is not a power supply or power converter. Please take care to match the appropriate power supply to the device.
Product Specifications
DC Power Connector TypePlug
BrandParts Express
Part Number335-370
UPC844632099328
I FOUND THESE PART NUMBERS FROM THE WEBSITE BELOW; their from the L-09M SERVICE MANUAL; I BELIEVE AK HAS IT ALSO AND OTHER SITES TOO-
http://www.scribd.com/doc/68434030/Kenwood-L-09m-Vintage#scribd
Product CategoryCamera Mounts, Power Supplies & Accessories
http://www.partsimple.com/e30-0594-05-ken-n-13.html
HAS IT ALSO SPECIAL ORDER Kenwood Part #: E30-0594-05 Remote Cord L07M- No Longer Avail Ka8300 L09M ? $31.65
MORE INFO I FOUND IN AK THREADS BELOW-
12/29/2007 redcoates7 said below-
Remote turn-on cable: E30-0594-05 (15 Meters Long)
- This is a cool feature, as it allows you to leave the amplifier in the "On" position full time, and power up from your preamp. Power for this circuit is contained inside the amplifier, so all you really need to be able to do is close a switch on the preamp side...no drive voltage is required so DO NOT connect this to the 12V realy output found in many modern preamps or receivers
Audio Cord: 050-1012-05 (12 Meters Long, supplied with L-07C II preamp)
- Very special by 1970's standards, but appears to be a simple, low-capacitance cable with a high-quality locking RCA connector. Be careful with whatever cable you use, as one sure-fire way to blow these amplifiers up is to disconnect a signal cable while they're playing
Speaker Cable (No Part number given) (1 Meter Long)
- Looks to be a very high quality mutli-strand cable. Stay away from crazy audiophile cables with magic boxes in them, as the Kenwood is fairly easy to drive into oscillation with a capacitive load...the downside of the "High Speed" design and extremely high frequency response. Check out EchoWars' excellent L-07MII thread elsewhere for a good description of the problem.
Key message here is to put the speaker as close to the amplifier as possible.
As for service manuals, check out vintageaudiomanuals.com. He doesn't list the L-07CII, (just the L-07C) but you never know... they sell some very high quality manual copies...spiral bound with excellent clear circuit diagrams, etc.
Have fun and enjoy those amps!
SEVERAL WEBSITES CARRY THESE CONNECTORS -LOOKS LIKE THE 2.1mm x 5.5mm x 9mm connector Power Plug to Screw Terminals from
Parts Express-Part Number 335-370 - UPC844632099328 IS THE BEST choice ABOVE to make your own cables without soldering the connectors on or use the Parts Express-Part Number 090-477 connector if you want them soldered. Same thing with the Radio Shack- Part Number 274-1569 if you want them soldered on.
The three part numbers below are from the L-09M SERVICE MANUAL-
KENWOOD PART NUMBER E30-0594-05 Remote Cord L-07M & L-09M
KENWOOD PART NUMBER E13-0115-15 PHONO JACK- ( SCREW LOCK TYPE )
KENWOOD PART NUMBER E30-0595-15 - SPEAKER CORD 1 METER IN LENGTH WITH 14 CONDUCTORS TWISTED TOGETHER IN TOTAL-THE BLACK CABLE TWISTED TOGETHER WITH SEVEN WIRES (DON'T KNOW WHAT GAUGE WIRE) & THE WHITE CABLE TWISTED TOGETHER WITH SEVEN WIRES (DON'T KNOW WHAT GAUGE WIRE; 16 OR 18 ?) As shown in the two pictures below I believe I found on AK. I made my speaker wires using a 100 foot long stranded copper wire 12 gauge three conductor extension cord I bought at Wal-Mart. It saves me a lot of money and I can get several different length speaker cables from it using good quality terminals and some good ratcheting terminal crimpers. I usually slip on a piece of heat shrink tubing first and then solder the crimped terminals on, then put the heat shrink tubing over the ends of the cables and crimped on terminals to help prevent corrosion over time. I don't have to worry about the wire pulling itself out of the crimped terminal either after soldering them on. Sometimes I use a liquid brush on or dip on plastic to seal the ends of the heat shrink tubing also. That's it for now. I need to find out the Diameter and Pitch/Threads Per Inch of the KENWOOD PART NUMBER E13-0115-15 PHONO JACK- ( SCREW LOCK TYPE ) special RCA type input terminal so hopefully I can find a substitute to use or have them
machined. I'll keep Ya'll posted.
