I picked up a pair of L-09M amps and one unit has some problems. I checked the power caps and they seems to be working fine. I found a lose connection in the RCA socket that is causing hum when the I/C is connected.
RCA cable is sort of acting like an antenna and it scares the chit out of me when I am hearing that hum. I wonder should I be doing an overhaul since it's about time.
I read some old threads that EchoWars has caps for the L-09M.
Paging EchoWars! Would you chime in please?
TIA!
TIA!
