KG4 vs Heresey 1
Jared R
Member
I listen mostly to hard bop jazz vinyl thru a Luxman R 1070 receiver into a pair of KG4's with recapped crossovers and titanium tweeters from Krites. A pair of Heresey 1's (stock) came up for a fair price. Would they be a better fit for my set up? Not interested in adding a sub as I don't enjoy a thumping bass. All opinions are welcome, Thanks
Wait till you find a good deal on a pair of Forte’s
Just to clarify my point,
Imho your Kg4’s are better balanced
Although not as efficient.
The Heresies do seem to have a remarkable
Resale value, although I can’t understand why?
I’m quite sure the Klipsch experts will surely
Voice their opinions.
If you see the pair you are considering
Are a bargain like a few hondo’s or less
And not trashed, you won’t loose money on them as you move up the Klipsch ladder.
Bobhorn
Although not as efficient.sey
Bobhorn
I think you are correct. I did find a pair of Forte's but wifey nixed it because the cabinets were too big! Go figure. Thanks for your input. The heresey's are not a screamin' deal,750. when most in my area are1,000 +
Bobhorn
Most likely the looks imho, the Hereseys are a good looking speaker
Forte take up the same amount of floor space as Heresy.
I heard a pair of Hereseys once. That was enough.
I've had KG4's for years. They do benefit from the Crites diaphragms if you're looking to update things, but the single best improvement I got was replacing the NP electrolytic caps on the crossovers. the film are fine, the NP went off value. Don't need to go fancy here, new NP electrolytics will do the job just fine.
Thanks, I did do the diaphragms and the caps from Crites. Think I'll stick with the KG4's
IMO, besides the bass output, no KG4 can compete with a Heritage 3-way speaker. Jazz would definitely benefit from a proper 3-way.
it would be a step backwards to go to a Heresy 1, which needs another $500 worth of upgrades to sound decent and still won't have the range of the KG4. a Forte would be better.
I've heard Cornwalls and thought they sounded pretty good. I don't think I've heard Fortes.
My issue with the Hereseys, besides the lack of bass, is I thought they were incredibly shrill yet somehow also lacked top end detail. It was like listening to someone yelling through a bullhorn. It was all the bad stuff people parrot about Klipsch speakers essentially. Not for me.
In my experience, Heresies are better with tube amplification. I used to run my first gen Heresies with a Yamaha CA-800 exclusively in Class A mode and it was okay but I switched to a Dynaco SCA-35 (push-pull tube amp with Dave Gillespies EFB and PC10A boards) and they absolutely sing. I love the combination... but I found myself using loudness because of the lack of bass and eventually added a subwoofer. This will probably be my system for at least a few years.
So, if I were you I'd likely keep the KG4s if you're set on the Luxman. But if you're interested in exploring tube amplification later, the Heresies would be great. That said, if you like hard bop, you'd probably want a subwoofer to really make the most of those bass lines and solos. Someone else mentioned Fortes and my understanding is they solve the bass issue—basically a Heresy with bass so no need for a sub. But I haven't had the pleasure of hearing them.
