KLH Model 10 restoration
AZ_Jim
Recently found these KLH model 10's in unfinished Birch and after a frustrating search for information or lack thereof on the web decided I had to have them anyway. A common story I am sure. A guy whose best friends grandfather had passed away had left these speakers to the grandson, who then gave them to the best friend. Grandfather had purchased them new around 1962 or 63. Best friend kept them a year or so and sold them on to me via ebay. This is my first pair of KLH speakers. I have enjoyed listening to them for a month or so when I noticed very little sound coming from one of the tweeters. Had intended to just enjoy them until they needed attention which came sooner than I had hoped.
Since my meager search abilities had turned up very little about this model and I was going to dig into them, decided to reach out the AK'ers for thoughts and advice as I go through them.
I could not be happier with their overall appearance and condition given their age. The cabs and grill cloth for both speakers are in great shape. Will leave the patina just the way they are and focus on getting the best sound possible from them.
First challenge was removing the plastic/rubber frame holding the grill in place. It was glued on at the factory. I slowly and carefully used a scalpel to cut through the glue and release the upper left corner of the frame. Then slowly continued lifting the frame all the way around the speaker. Once removed the grill just fell out. As careful as I was, still managed to put a small tear in the plastic/rubber frame and break off part of the tapered edge that the frame had been glued to. Overall, I guess the best outcome I could have hoped for, but still felt like a fail given how nice they were to begin with. Is possible to still use the frame when putting it all back together, but have thoughts about replacing the original frame with custom frame made with unfinished Birch attached in way as to be easily removed. Not sure if I can do so and keep the tapered cabinet edge or remove the edge and make the new frame fit flush.
So, anyone who has already been down this road or has some detailed specs and info on this model and pass it along, would be greatly appreciated.
The serial numbers are 10290 and 10297. Would hope that means they were matched before being sent off.
The crossover information was as follows:
Resistors:
tweeter 4 ohm 10%
woofer 7.5 ohm 10% X 2
Capacitor:
SYNCRO EP25257
RED 2X4 MFD 50VNP
BLK COM NEG
10816301
Unsure how to proceed from here. Need help on what capacitor (s) to replace with brand, type, values etc....
If I should replace the resistors or not and if so, brand, type, values etc.... along with where to purchase.
Think I read there is a recommended product to reseal cloth surrounds available on ebay?????????????
20170422_070018.jpg 20170422_070133.jpg 20170422_070651.jpg 20170422_070744.jpg 20170422_072211.jpg 20170422_072346.jpg 20170422_072932.jpg 20170422_073000.jpg 20170422_073607.jpg
Will post some pictures for now. Have taken many so far in case another angle might be helpful to needing them.
I few more pictures:
Thank you gtv2000.
Anyone with any more model info. / spec's, history, insight, experience etc....?
Trying to gain knowledge about these. Documents or links would be helpful :).
A ported KLH. Those are neat, KLH had a couple of ported editions, not many. I imagine they tuned it well. Possibly more efficient but I won't pretend to know. But I like!
As far as appearance, I'd separate the functions- finish the trim for the cabinet, then cut a frame for
the grill cloth. Velcro that on the front baffle.
Interesting that the drivers are all bolt-in. A lot of early KLH have the moulded in drivers. I don't know if that is any indication of age though. The blond color hints at an early model.
The Ten was one of the first models that started out with removable drivers.
The Model Eight radio had a satellite speaker that was probably the first.
The Six started with epoxied units, but was revised in the '62-'65 period.
These are ported with cloth surrounds. Most vintage KLH speakers are AS, and benefit from a light coat of sealant on the surrounds. Will this be the same with a ported design? Just curious.
Others may respond, but I'd vote for sealing them because you still want the air pushed through the port and not through the surround. If it escapes through the surround I have to believe that there will be a sonic difference in the low end.
+ 1 on that, makes sense. It may also help to preserve the cloth; feels pretty fragile unless sealed with the AR goo, although I've never had any disintegrate.
Thank you Finjima for the sealant tip. Will get the kit as part of the project.
Thank you RxDx for the specs link and grill ideas.
Finjima mentioned Film caps and gtv2000 mentioned electrolytic NP caps. I really appreciate the input, and apologize for the newbie question, but are there pro's and con's or noticeable differences / reasons for the type of replacement capacitor ?
AZ the subject of caps is complicated and subject to how deep your pocket book is. here is one link to give you a appreceation on how far people have gone trying to understand the subtle differences between various caps, please note most caps mentioned are pricy but you won't be looking for those ones for this speaker. the ones they sell ar part express will do you fine. http://www.humblehomemadehifi.com/Cap.html most people lean twards getting the film caps for cross overs. feel free to google questions regarding caps also, lots of threads on it
I just got a set of KLH SA-9X from the thrift store for $10, can't find anything on the internet about them, woofers blown, replaced the 15's with laminate's but I'm thinking since they r pressed wood w/ laminate, they r what the Japanese put out after they bought KLH.......Are they worth my build? I'm hooking them up to a 73 Pioneer SX 828
